So one thing I've thought about, and now having "don't add peak nits" makes it very easy to test apples-to-apples, is the conventional wisdom about DPL, and no compression limit, and not lying to madVR about DPL. And I know this has already been discussed in the past, but please be open-minded, and hear me out.
So I understand the reasoning behind not lying to madVR about DPL, and how the no compression limit is intended to address concerns about "protecting" a critical range while allowing frames with peak < DPL to map 1:1. But I think there are some important considerations:
1. madVR essentially lies to itself all the time, in the form of DTN and any resulting target > DPL, and also when NCL is used.
2. When using SDR output, due to the relative nature, it actually does not make any difference what DPL is actually set to, the target is what dictates what the frame will look like.
And to prove this, I did some testing.
Profile 1: DPL 65, DTN 60, NCL 103 - Resulting FALL multiplier of 2.175
Profile 2: DPL 103, DTN 54, NCL 103 (I don't believe this NCL matters in this case) - Resulting FALL multiplier of 2.174
I intentionally used the formulas I posted recently to find a DPL/DTN combo that resulted in the same multiplier and thus the same targets, and this is what I meant above when I said "don't add peak nits" helps test this apples-to-apples. I've theorized about this previously, but finally took the time and was able to actually test it.
Here are some examples of what happens with these two profiles with different peaks/FALLs...
Peak 400, FALL 75 - Target of 163 nits in both cases, end result is identical
Peak 300, FALL 20 - Target of 103 nits in both cases, end result is identical
Peak 120, FALL 10 - Target of 103 nits in both cases, end result in identical
Peak 80, FALL 7 - Target of 80 nits for Profile 1, Target of 103 nits for Profile 2
Peak 50, FALL 5 - Target of 50 nits for Profile 1, Target of 103 nits for Profile 2
So the only difference between these two different approaches is in the case where peak is less than the 103 NCL/altDPL. In this scenario, Profile 1 maps 1:1 (or to peak if in between DPL and NCL), while Profile 2 maps to 103 nits. And in a vacuum, mapping 1:1 when possible seems like a reasonable goal. But let's consider how this is really working in practice.
So I ran through a scene in Valerian which has a mix of frames with peaks <65, between 65 and 103, and >103. And within this same scene, Profile 1 is jumping around between 1:1 mapping for the <65 frames, mapping to 103 for the >103 frames, and in between on the frames between 65 and 103. Profile 2 is consistently mapping to 103 for the whole scene. FALL is never high enough to kick in a higher target via DTN.
Keep in mind this is all within the same scene. The only major difference between the <65 frames and the higher frames is whether something semi-bright is in the frame or not. And so in the case of Profile 1, the scene is mapped inconsistently, while with Profile 2, it is mapped consistently. So I think we need to take a step back and ask ourselves, do we only want to "protect" the critical range (however one wants to define that, 75 nits, 100 nits, 106 nits, 200 nits?) which NCL does, or do we also want to ensure consistent TMing within that critical range as well (which NCL does not do)? Do we really want frames within the same scene to be mapped inconsistently through this critical range? This is importantly different from inconsistent mapping above the critical range, which is a necessary evil of TMing and not too detrimental with good target smoothing. As you ask yourself these questions and answer them, keep in mind that this is the
only difference in the end result of these two profiles due to the relative nature of SDR and that it really does not matter whatsoever what DPL is set to otherwise.
This is easy to test now with "don't add peak nits". You just have to create a second profile with DPL equal to your current NCL and then use the formulas I posted to find a DTN that results in the same multiplier as your current DPL/DTN combo. I'm happy to help anyone with this if they need it. Cheers!
Edit to add: This really only applies to those with DPL which is less than the "critical range", i.e. those who are (or maybe should have considered) using NCL to protect this critical range. But that does seem to be most PJ users here. See, we high-nit users
do care about low-nit users!
