  • Take part in a short activity and share your valuable opinion on new design concepts for AVSForum! >>> Click Here
In ceiling wireless speaker options
313 Views 2 Replies 3 Participants Last post by  sigpig
Hi,
I am looking at a possible 5.1 setup in the main living space of my home and am considering putting some in ceiling speakers in the rear behind the viewing area for the surround setup. Running wires for the in ceiling may present a hit of a challenge. Are there any recommendations on wireless in ceiling options that people can speak to?
1 - 3 of 3 Posts
Hi,
if you can't run speaker wires, how are you planning on powering the speakers? do you have access to a power circuit there?
There are wireless surround options that have a wireless transmitter/receiver combo + amp... somewhat problematic in that most usually use the 2.4 ghz band, which is often crowded and you might get some interference or unwanted pops, etc. - check rocketfish (best buy) or parts-express. there is a pro-level set up from Alto; the Alto Stealth.
good luck
Nope.
1 - 3 of 3 Posts
