I am in the early stages of constructing a new home and am working with a home automation consultant to get the wiring plan set. My wife won’t go for floorstanding speakers in the TV/family room unfortunately, but she’s open to in/on wall speakers. The consultant is actually recommending an all “in ceiling” system using angled Paradigm P80-A for the LCR, P65-R for the rears, and an in-wall sub. He claims it will perform as well as in-wall LCR, but based on all of my reading on here I can’t believe that’s actually true (he’s really great at automation, but I trust him less when it comes to audio quality).
I think I’ve read all of the recent threads on in/on wall speakers, and I’m still not sure I’m close to knowing what is best for my application. Here are the room details:
Based on all of this and what I’ve read on here, these are currently on my shortlist.
Thoughts on these options? Others I should be considering instead?
Thanks for your help!
- This will be the main TV/movie room, but music is also quite important to me. In a lot of the threads on in-wall speakers, music seems like almost an afterthought to HT. Room dimensions are 15' x 12' 6" x 10' ceiling.
- The TV will be 82”ish and wall mounted. Probably going to need to position the center channel horizontally above or below, which I recognize is not ideal.
- The couch will be against the back of the room with built-ins above – in-ceiling speakers for the rears seem likely the best option.
- As you can see from the picture of our room, the family room opens into the kitchen. Not sure what, if any, challenges that presents. The back of the house is going to have a lot of glass (doors and windows), but there’ll be privacy screens that will likely be down much of the time when in use. I’m hoping that will help with reflection issues, but maybe not.
- WAF Aesthetics – seems like most in-walls have paintable grills these days, but if some brand has a particularly clean look, would be good to know; if on-wall, speaker would need to be attractive and relatively shallow.
- I’d like to keep the budget for the LCR to around $1000/speaker, if I can. If going to $1500/speaker would allow for a substantial jump in performance, I’d consider it.
- Revel W893/W990 (use same for horizonal center or some other Revel model?)
- GoldenEar Invisa SPS (use SPS or MPX for center?)
- Paradigm CI Pro P3-LCR (use P3 or P1 for center?)
- Totem In Wall or On Wall – no idea which version would be best for my application or whether they are within budget
