1 - 3 of 3 Posts
So my wife and I are planning a new house and in the living-room there will be a TV but the 5.0 will need to be inwall. (Planning for a separate media room system discussion is elsewhere
). The 5.0 will be crossed at 80Hz to either one or two Salk/Rythmik subs.
The living-room will be sunken by 2 steps, and the speakers will have to fit in that space.
The two key contenders at this point are:
1. KEF Ci200RR
Reference series, 8 inch co-ax, 90db sensitivity.
The thought would be to build custom, front-ported boxes for these and install them in the wall,
2. Tannoy DC8i
Definition series, 8 inch coax, 92 db sensitivity.
These come in front-ported boxes, so ready to install.
Does anyone have any experience with either of these speakers? Feedback, thoughts, other suggestions?
Also, I have looked at Triad's site, but think these are likely too tall.
Discussion Starter · #3 ·
Design is not yet finalized, but 2 steps are generally about 15" - so I will likely be limited to about 12" in height, I should have a certain amount of play in the other directions.
1 - 3 of 3 Posts
