Just hoping that some of you who have mounted 42" and 50" 7UYs to a wall could share advice/info/photos of how and where you ran the wires through the wall and why.
Specifically:
- Did you cut one large hole for all of your cables and then bundle them together and run it through?
- How much vertically above the set's bottom edge did you cut the hole?
I figure that I'm going to run everything that can be connected to the set to avoid having to do much in the future, unless I'm changing a board out. This means:
1 DVI cable
1 RGB cable
3 separate BNCRCA cables for my component connection (they're each thick - broadcast-grade)
1 composite video cable (also broadcast-grade)
1 s-video cable
2 sets of RCA cables (just in that off, off chance that I hit the lottery and can afford to purchase those ridiculous side speakers for pure convenience
That's a pretty thick bundle of cables. Power I'm running separately.
Any info appreciated!
Specifically:
1 DVI cable
1 RGB cable
1 s-video cable
