1 - 2 of 2 Posts
· Registered
I am setting up a 5.1 surround setup in my 16x17 family room with the following setup and want your recommendations/feedback.
Rear In-ceiling: Polk Audio MC60
Front(L&R) In-wall: Speakercraft MT-6 One
Center In-wall: Speakercraft AIM LCR 1
Subwoofer: Definitive Tech PROSUB 800
Receiver: Pioneer Elite VSX-32
My Questions:
1. I was told that having silk-dome tweeters would definitely enhance sound quality in a hardwood flooring setup. Can you comment on this?
2. The PROSUB 800 also has a downward firing Sub. Can I have the sub placed on the floor(hardwood) or do i need to have a thick carpet underneath the Sub to prevent vibrations?
3. My room is fully hardwood, so is there anything I need to consider while setting this up.
4.Do I need acoustic damping only on the In-ceiling speakers or do I need to have them on all of them.
Thanks in advance for your valuable inputs.
Chan
· Registered
How is it listneing to TV? terrible I imagine, like our living room.......get yourself a rug and as much soft furnishing as you can.....see how that goes, if its still horrible its really, really difficult to fix (in a nice way) unless its a dedicated room
I am about to get a down firing sub as well - everyone is telling me to put a mat under it.....it seems a little daft to me as you need something really thick (like 2 ft) to absorb real low frequencies. The reason might have something to do with a reduction in pressure against the driver? not sure
Cant comment on that - sounds like a bit of a crock though, its not like a hardwood floor diffuses sound well. Soft domes decay faster in air generally, they might be saying that the relfections from all the hard surfaces "enhances" the experience - who told you that? a dealer?
1 - 2 of 2 Posts
