1 - 3 of 3 Posts
I have been looking at the Klipsch website and found a few I like. Are these what I should be looking at. I have had a pair of Klipsch KG-4 for over 20 years.
My home theater will host a lot of sports partys. So I want it to sound like you are at the game.
For the front and center I have choosen to sets
r-5502-w fronts and center
r-2502-w fronts and center
r-5650-s rears
r-2650-s rears
Any help would be great. I need to buy the plates to install before the drywall gos up
Depending on how large your room is, you might also look at the KL-6502 and KL-6504 THX Select speakers. Barring that, the 5502 is a significant step up from the 2502.
Reviving this old thread, as I thought others might find your feed back usefull. I did a search on R-5502-W and found it. I found it ironic that you've had the KG-4's for 20 years as I also have a pair of KG-4s (for 20 years
) and am about to upgrade my theatre room similarly to how you did.
R-5502-W front and center
r-5650-s suround
KSW200 sub
and a pair of r-5650-s for front precense speakers.
I wanted to know what you decided on and how it turned out.
1 - 3 of 3 Posts
