I am looking into in-wall volume controllers for in-ceiling speakers. Researching this I came across some questions:
1) Some claim (significantly) reduced sound quality. Is this a concern? If so which brands are good/best?
2) It seems the IR part needs power at the controller. I plan to run an Ethernet cable to each controller. I think this will be enough to run the IR signal back to the central location and also provide power from the central location (rather than locally with a DC power adapter). Are there any concerns with such a setup?
3) For instance, the monoprice Prod # 10221 says "Built-in single-band (38khz +/-2khz) IR repeater". Does this cover pretty much all IR signals for A/V equipment or could this be a concern?
4) Do you have any in-wall speaker volume controllers with IR that you can recommend?
