1 - 5 of 5 Posts
Hi. I'm trying to decide on in-walls for my 19'x20' home theater room. I have a limited budget so I'm looking at $150 per pair or less area.
Here are three candidates I'm considering:
1) Polk rc85i ($150 per pair)
2) Boston Acoustics DSi-280 ($90 per pair)
3) Dayton ES80W ($120 per pair)
I will not have an opportunity to audition any of these so I thought I would see if any of you have thoughts on them. Alternatively, if there's something else you'd recommend, please let me know.
A fourth option is the Axiom M2 v3 in-walls for $269 per pair, but their substantially stretching the budget. Would they be a substantial improvement over the above speakers?
For a subwoofer, I'm looking at the Boston Acoustics 12" 300w HPS12HO for $150. Will this do the job, or is there something better in the same price range?
Thanks for any input you can provide!
for the large room, you need large speakers - so the 8" units are the starting point. Of the three speakers mentioned, the Polk rc85i are probably the best option.
I'm not sure where your are getting a BA HPS12HO for $150 - that is a very good price for the 12" model. It may need a twin brother to properly fill the room volume, but you can get the second unit - if needed - when the budget refills.
Emotiva has 8" inwalls as well worth a look.
1 - 5 of 5 Posts
