Status
Not open for further replies.
1 - 5 of 5 Posts
Does anyone know of one? I've seen some inexpensive A/V switches that switch 3 RCA (R/L&Video), but am concerned that they may not have the bandwidth to stand as HD Component video switches.
If the switch is completely manual, do I need to worry about bandwidth?
jake
I tried one of the $15 radio shack A/V switchers, and I really can't see any difference running through that or going direct into the set. I'm using it to switch between HD and progressive DVD.
I figure try it and return it if it doesn't look good to you.
--JD
--JD
Tried the RS,BUTTTTTTTTTTTTT, see
http://www.avsforum.com/ubb/Forum11/HTML/016363.html
I am not sure the malfunction is not entirely temporal amd coincidental, but I could envision that passive switching COULD short between sources transiently, although I am not sure why that would be a problem. Just TOL.
Bill
Cranial Nerve II With control by III, IV, and VI
1 - 5 of 5 Posts
Status
