Status
Not open for further replies.
1 - 6 of 6 Posts
I'm considering getting a plasma screen to replay my RPTV. If I do that I'd like to move just about all my hardware down to the basement, which is right below where the plasma would be going. I would also like to put my DirecTV boxes down there and feed that feed the bedrooms (I already have the RF distribution for that up and running).
What I'm looking for is an inexpensive wireless IR remote system that has multiple transmitters to feed to a single receive that would allow me to connect multiple IR emitters to for controling all the stuff I'd be putting down in the basement. I've looked through this forum and surfed a bit and I haven't found anything that really fits my needs that it's out of my price range. Any suggestions??? Thanks - Rick
Discussion Starter · #3 ·
Originally posted by MetalMike
i SUGGEST you tell us your price range.
I would like to keep it around $200 or so.
Discussion Starter · #5 ·
A Niles IR repeater system will work for about $200
I found some info on the Niles system but from the site I've looked at it's a wired system, I'm looking for wireless, unless I'm missing it. Do you have a link??? Thanks
1 - 6 of 6 Posts
Status
