I am looking to buy a new receiver. I am on a budget so I decided to keep my speakers for now. I know they probably aren't the best. Heres some info
Satellite
Woofer 3.5" shielded
Power Rating Use w/amps rated between 15 - 80 watts RMS
Frequency Response 200Hz - 20kHz
Feature 1 MINUETTE SATELLITES (2)
Tweeter 0.5" polycarbonate w/acoustic lens
Nominal Impedance Compatible w/8 ohms
Sensitivity 87dB @ 1watt/1meter
Crossover Frequency(ies) 5kHz
Center Channel
Frequency Response 150Hz - 20kHz
Feature 1 MINUETTE CENTER
Nominal Impedance compatible w/8 ohms
With that said I just found this info on the site. These are rated 15-80 watts...What would happen if I hook up a 100w per channel receiver to these??? How would this work? If this is the case, i will have to get the onkyo receiver for the most part right?
Any help would be greatly appreciated.
Satellite
Center Channel
