Now what about for HT use specifically, combined with a subwoofer?
Because I remember people saying when I made the decision, Infinity or something else like the JBLs, that the JBLs have a fuller sound, better bass, etc, but maybe the Infinity's had cleaner highs, maybe mids, at least definitely the Infinity RC263 center channel did vs the JBL center channel (the weak point of the JBL lineup, apparently), and maybe some of that carried over to the towers too.
But that on the flipside, the Infinities could get a little too high and clean, so to speak, or something.
But people mentioned, for home theater use, if you just have your subs take care of the bass completely, then you're getting the clean mids from the Infinities, the clean bass from the subs, and maybe, I have no idea if this is how it works and no one really specified, the subs can even compensate the highs of the Infinity's and give you sort of the ideal combination, Infinity's = high, subs = low, and together = perfect
It's a total oversimplification but do you think, if you were using just for home theater combined with subwoofers, you would have kept the Infinity's, or still JBL will work best in your opinion for home theater with a sub as well?
Maybe the ideal combo (if you have to use a center channel) is the RC263 center, and JBL towers instead of R263s?
