1501 - 1506 of 1506 Posts
The mounts can tilt and rotate 180 in all directions.
Okay great. Is there a way to mount the speaker more to the bottom of the mount, not the top? Or, how long is the mount pole?
It's great work. Is a lot of it custom built or could someone who doesn't know $#@! about DIY like me be able to put it together if I know the different pieces to buy?
I should really just take a picture holding the speaker exactly how I want it to be at exactly the spot I want it to go, and maybe someone can help. I will get on that.
Did you drill into the speakers to attach the bolts? Can't really see how the mounts are attached to the speakers in that last photo.
