Status
Not open for further replies.
1 - 19 of 19 Posts
I am at IDF and they have an xbox 360. I didnt take any pictures but anandtech has taken some. HD cable has component connection as you all know, it also has digital audio coax cable.
check out anandtech
Akshay
Banned
"it also has digital audio coax cable. "
so the optical cable is included now? or is it just the connection.
what about the $299 package?
Or is the optical connection directly on the unit like the PS2?
Originally Posted by alczervik2
i think its the composite video conncetion
I was under the same impression. It makes sense considering that the digital audio connection is likely to be more distant than a person's component video connection resulting in the coaxial audio cable being useless.
Might be just my eyesight but on these high res pics, it looks to me that the optical out is on the upper part (in the pics) of the connector. If it is, interesting that it's available with all three wire combinations shown.
And damn right I'm getting the faceplate with the flames.
That yellow cable connection certainly seems to be just composite video, not coaxial digital audio. I haven't seen any shots of the back of the box, but I wouldn't rule out the possibility of the X-Box just having a digital optical port directly on the box, i.e. without use of a break-out cable. The PS2 went this route last generation, after all.
I agree, if you look closely at the connector that attaches to the console adjacent to the cable that leads to all your RCA plugs looks to be the optical out.
Ok, I had a question about this as well that i recently posted on another thread. The digital audio on the X360? Ok here is a picture of the HD-AV Cables: HD-AV Cables . In this picture you can clearly make out 6 wires: RGB for the component video and Yellow, White, Red for the COMPOSITE connection (remember: M$ said the the X360 will be able to be displayed on standard and HDTV out of the box). Well, I don't see any audio connectors what so ever.
Looking at the back of the console here , we see the A/V input and the I/O connector (ethernet etc). There is no optical output on the console for sound as far as I can see. So, the only solution left is that there is a digital coax cable (somewhere) that gets sent to the ~30 pin A/V connector. I hope this is part of the HD-AV cables. M$ has said it is, but I don't see it.
If you buy the $400 premium package, not the $299 core system, MS will be correct: You will be ready for HD and regular TV out of the box.
The red and white cables are for analog audio, which will work for both composite and component video connections. The console design could be preliminary, so the back layout isn't necessarily finalized. It looks as if Microsoft might sell digital audio cables separately in the form of mini-to-optical and/or mini-to-coaxial. You can see something like a mini connector on the actual cables.
Look at the high resolution shots, the optical out is on the portion of the cable that plugs into the console.
I'm not sure if you noticed, but even the original xbox didn't have have a digital audio cable in the HD Pack. Nor do any DVD player or or device with digital audio connections. :) However, it did have an optical port on the HD pack (as does the Advance AV pack). The pictures of the 360 cables all have an optical port on the opposite end of the cable. It's up to you to get the digital optical cable.
Ditto. I question wether it is a Toslink connection or will there need to be an adapter like with my Monster cables? Not sure of the name for the Toslink to miniplug thingy.
To me it looks like a generic mini connector for mini-to-optical and mini-to-coaxial cables, which can be bought from other companies.
Originally Posted by nothru22
Looks like a regular sized optical connector to me.
Me too. Glad my eyesight doesn't appear to be that bad after all.
Yup, it's been confirmed now that there is an optical output on the back of the HD-AV cable which should be able to be used with a standard digital optical cable. It's nice that this cable will come with the X-Box 360 Premium package, although one will have to supply the actual optical cable oneself.
1 - 19 of 19 Posts
Status
