The bigger of the two connectors is the M1DA connector.
If you can swing it, I suggest that you install 2" conduits for cables instead of just installing the DVI cable. 2 conduits ought to cover any future needs.
You can end up needing cables that you don't currently envision needing. Currently, I have 3 sets of component cables, 2- Svid cables, 1- composite cable, and 1 DVI cable. It is sure convenient to be able to run a new cable without opening up the walls and ceiling. Running the conduit is easy and cheap while the house is under construction.
Glenn
