First of all, let me tell you I've just discovered AVS Forum and I'm blown away by the high quality of information on this site.
I am working with a dealer (whom I personally like very much) to put together a dedicated HT in the basement of our new home. Although the home is 1920's vintage, I am forunate that the HT will be in the unfinished basement part of a largish addition that was completed four years ago. The HT will not be huge - about 16' long X 14' wide by 6.5' tall. The ceiling height is a challenge but it is what it is.
The dealer carries Infocus and Sim. At first I was himming and hawing about the SP 5700 vs. the 7205 but I ultimately decided that I wanted full HD resolution, plus he is giving me a good price on the 7205 because he wants to show Infocus that he has the ability to move their higher-end models.
Now of course I am nashing my teeth wondering if the 7205 is the right projector for my needs. This will be a dedicated HT with no ambient light whatsoever. I will be using a 103" (diagonal) screen and sitting 12 feet from the screen. Due to the low ceiling, I need to use an acoustically transparent screen (Vutec Vu-Easy Soundscreen 0.95 gain).
My main concern is that the 7205 will be too bright for the room, given the complete control of lighting that I have and the size of the projected image. We are going with a low-gain screen (I am worried about Moire effect because of the cloth) and I will utilize an ND filter to tame the light a bit more but reading extensively about this projector, most reviewers say that it is best suited for rooms with some ambient light or when a very large screen is desired.
Often times in shootouts reviewers will not come clean with a clear favourite. They will say Projector A is best if you want, say the best optics, Projector B best for colour, C for its brightness etc. But here is my question: Are the aspects of the 7205 other than brightness on par or better with comparably priced DLP projectors? That is, if its brightness was not as good as it is, would the reviewers say "amazing HD image" or "gorgeous, natural colors" or "complete lack of screen artifacts".
As a humble enthusiast, I find the choices and considerations overwhelming. I really want work with this guy because he's a good guy and has been very helpful. However, he does only carry the two projector lines, which doesn't give me too much flexibility. Thanks in advance
