Status
Not open for further replies.
1 - 2 of 2 Posts
I have recently bought an Infocus LP-340V projector and wanted to double-check with you owners if my assumption is really correct:
The Infocus LP-340 has an option in the menu setup where you can specify the amount of time the lamp stays on AFTER the standby button is pressed. After the specified amount of time is elapsed, the lamp goes off, but the fan WILL stay on FOREVER, unless I press the power button or switch the power off.
Since I'm placing the projector on the ceiling, this is really annoying, as I won't be able to easily reach the power button.
Infocus LP-340 owners, please correct me if I'm wrong, but is that the way this unit oddly works?
Fernando Schaeffer
That is correct. The fan will continue forever...
There were a couple of threads regarding this topic in the past.
The easiest solution will be a switchable power outlet.
Dirk
1 - 2 of 2 Posts
Status
