I need help troubleshooting the component input of my infocus X1. I have tried to hook my Xbox and My Panasonic DVD/VHS combo to my Infocus X1. The Xbox is using a Xbox high definition av pack in order to provide Y Pr and Pb Outputs. My Panasonic DVD Player only Outputs High Definition when playing a DVD and not when playing a VHS or Cable Television.
When i plug either my Xbox or my DVD unit into the Infocus X1... The Infu]ocus does not find the Video Signal and continues to search for one.
The Infocus X1 has a VGA to Component Adapter going into the Computer In port. I made sure to select the infocus source as Computer. I have tried two different cables.
I also attempted to verify that the RCA cables are working. I Did this by plugging in the Y(Component[green]) output of the Xbox into the Yellow Composite input of the Infocus X1. I did this for each cable and every time i got an image sync on the Infocus X1 but it was in Black and White every time.
Is it normal to see Black and White when connecting Green Component to Yellow Composite?
When i Connect my laptop to the Infocus X1 via a 15pin VGA to VGA cable it works just fine. This makes me think that the Infocus is fine and that the Xbox and DVD player are fine. The only thing that i have not tried to test is the VGA to Component Adapter.
What is the Pin out of a VGA to Component Adapter?
What other troubleshooting techniques can i try?
Is there a way to verify the output of my two devices?
I would like to take my multimeter and verify that all the pins are connected and that i don't have an open circuit in the adapter.
Thanks for everyones help in advance.
