501 - 520 of 4,407 Posts
Discussion starter · #501 ·
Originally Posted by G342 /forum/post/18305322
I was recently looking at the 65''S1 Panny actually.. Does anyone in this thread have any experience playing on it?
So should I buy the Panasonic, after roughly a 100 hour break in period, I shouldn't have to worry about IR or burn in (to a point) when gaming ?
correct, as long as your not abusing the TV and leaving static images up for 3-4 hours at a time regularly you will never get burn in and you will likely see some temp IR on a black screen but you can remove this easily and quickly by watching some normal HDTV on it or using the built in IR remover for 10-20 min or more depending on the amount of IR
we get IR on our panny 50X1 because my brother loves to listen to music using our asus O!play, it has a screen saver but he changes tracks so much that it rarely activates and lots of white static images n such are left on the screen for hours at a time, afterward I've only seen some really minor IR at night when the screen is black and the IR remover in the TV has removed it in less than 10 min each time i see it, on normal program material i never see this small amount of IR and during the day its impossible to see it on a black screen as well
i've yet to see IR incurred by playing video games on it because while there are static images on the screen in most games it does change from time to time and as long as you take breaks (i hope you do! hehe) and don't leave a game on a pause screen with the TV on you will not have problems ever. something useful many people do is when they are going to pause a game for a bit they either turn off the TV or switch it to a blank input
Originally Posted by ToiletSiphon /forum/post/18304234
There are some input lag tests that have been done on the EX500, tho I don't know how accurate these might be, since they were made with a laptop...
Here's the video:
http://www.youtube.com/watch?v=yy4p7yTpZ9w
That looks like the same 2008 MacBook Pro I used for some of my tests. I measured it at less than one frame behind a CRT, probably more like .5. This was before I started using SMTT, so it's not a precise value, but it's enough to make me think it's reasonable for use as a benchmark display.
I have to say that 100ms is appalling for a "game" mode, but it matches my impression from some in-store testing of another Sony 120Hz set (V5100.) I don't have hard numbers, but it was slow in game mode, slower in 120Hz mode, and the motion smoothing didn't even work right -- it made Rock Band lyrics stutter and jump.
His other video of Counter Strike really shows how high lag can mess up your game. When he moves side to side quickly, you can see that he's sometimes facing in the opposite direction from what's shown on the TV.
If the game has a persistent HUD (which practically all of them do to some degree), black screen IR is guaranteed and can remain visible through several hours (or days) of "wiping" content (e.g. full screen TV, scroll bar wipe). This is what my G10 looked like after 15-20 hours of Dragon Age over 4 days. There were equal portions (15-20 hours) of general full screen TV viewing and Scroll Bar wipes interspersed over this same period. Camera is admittedly exaggerating the effect, but it was easily visible (in person) in a dark room. The reason you will see conflicting reports on this is due to environment. As bad as that looks, it would be virtually invisible with so much as a table lamp turned on in the room. If you don't have a critical environment, you might not notice it or care. It has always gone completely away in my experience, but it's a bit of an annoyance.
No mention of your now-infamous rising black level thread?
Seriously, though, haven't some people reported increased IR after the MLL rise?
At least IR is a temporary nuisance. I haven't seen any reports of permanent burn-in on current plasmas.
Originally Posted by frito /forum/post/18304780
...the B series models broke the speed of the special HDMI/DVI PC mode i did read somewhere that samsung recognized that this had happened and claimed they would fix it with the C series and his C7000 test indicates that they are trying but 30ms is a far cry from the 5-10 ms that the A series got in this mode but 30ms is acceptable to most gamers but i can almost guarantee you it will only be like that at 1080p and on 2 input's only (the one labeled HDMI/DVI and the VGA input)
So no 2010 (C series) models are lower than 30ms and you have to go back to 2008 models to get an A series? Did they make any 32-37" sizes in the A models, and do you know if there's any still around? I suppose even if there were they'd be inferior in any motion processing used. I noticed the smallest C series set is 40". I'm guessing the same is true of the A series, IF you can even find one.
Discussion starter · #506 ·
well so far we got 2 C series that have been tested one was a 720p 32" and in game mode it still had high lag, i think it was like 40-50ms something like that in the special PC mode at 720p
the C7000 someone posted in here in the special mode as well as VGA in tested low (30ms) but only with the LED motion setting or something turned on apparently (something new i guess on the sammy edge LED's)
i still hold out judgment on Samsung new line overall until i can see more tests done on various other models and get a clearer picture of what is going on with them and input lag
Discussion starter · #507 ·
yes there has been reports of more rapid IR after the voltage increase that causes the black rise, this makes sense because its a build up of excess voltage in the cells that is what causes IR but as Orta said this type of IR only becomes apparent in a very dark room with no lights on with an all black screen on the TV, if you turn on a light its gone or barely visible if its bad IR and with watching normal TV and movies that have been zoomed to crop the black bars (i always watch movies like that on our plasma anyways i hate bars) you will never see TIR on a panny plasma even after the voltage/black rise happens
our 50X1 has now clocked just over 400 hours and should have had the first voltage increase happen by now yet i still see no real change in IR or black levels on it, i guess only time will tell after 1k hours if it becomes a problem to my eyes but thus far it is not
interesting thread just to chime in about the A650 Samsung LCD TVs with the special HDMI2/PC mode or VGA input. The low lag was only available for the 40", 46", 52" A650 LCD TV models. The low lag was not available for below 40" A650 TVs even if put in PC mode or VGA sadly.
The components inside was actually different between the 37" and below A650 TVs and the 40"+ A650 LCD TVs (plasmas idk about them). For one thing the A650 40" and up were guaranteed Samsung panels (better quality) but ironically had the faster mode for input lag lol and none of the crap with the B series. The 37" A650 and below TVs weren't guaranteed Samsung panels if it even had the S-panels.
New A-series sets are long gone. You'd have to take your chances on a used one. CORRECTION: There's a handful listed on Amazon right now, but you'll pay as much or more than you would for a C-series.
It's also worth noting that the PC mode significantly degrades the picture quality. From what I've read in the A650 threads, it's tolerable, but if your primary use is gaming, an A650 probably isn't your best choice.
We need to consolidate and clarify this info. It's getting too spread out and confusing.
So certain screen sizes of the A series had a decent lag time over its VGA connection, but image quality suffered.
Now on one particular 1080P C model we are seeing 30 ms when compared to an lcd monitor (I thought this means more like 47ms) in special mode (what the heck is that and was it not using a VGA connection?) and VGA mode (with a VGA adaptor from the game system I'm assuming) when LED motion setting turned on (what the heck is this and does it improve motion blurring)? We predict that turning on game mode will actually increase lag. And we have no confirmation of what the B series could or couldn't do.
We need to clean this up.
Hi,
First of all thanks for the effort and time you guys are putting into this! Even if the display I was interested in haven't been tested accurately here so far, this thread helped me a lot to understand the input lag issue better. That's why, now that I got my new TV at home and I have some days to try it out, I want to make sure I do some proper testing before I make a decision, so someone else can benefit from it.
I do think I'm pretty sensible to things like monitor refresh rates and input lag, and reading about all these issues always made me hesitate about getting a HDTV. Also, the couple of times I've played games on friends TV's I've noticed some lag, and personally I hate to be aware of it when everyone else seems to happily game away. They probably think I'm completely nuts when I mention it
Anyway, I finally decided that the superior screen size and resolution was worth some possible lag issues (and that I might be just crazy after all) so I got myself a new TV, a 42" LG SL85 (internal specs identical to SL80, SL8000 and SL8500)
After gaming on it for some some days I have to say I do clearly feel a small lag, but I also get more used to it than I thought I would, so I can still enjoy the games even if it bothers me from time to time. Testing the Game profile made me think its just that, an image profile and not a Game mode but I have no real numbers on it yet. In theory labeling a port as PC makes it even faster, but the strange thing is, it disables different settings depending on the source. For instance, using an Xbox as source (and label as PC) grayed almost everything out in the settings, while it grayed out less settings when connecting my Macbook or my desktop PC. Don't know if this is normal. I also switched the ports to see if that made a difference, but no. I will check all this again because I did it very late at night and I started to feel the input lag in my brain
I also did some tests with the flash timer at flatpanels.dk. At first I used my Macbook (white 13" 2007 model) for my tests but that was completely unreliable and useless as the application struggled to show the numbers evenly and made jumps from time to time. But then I hooked up my desktop PC and run the same tests and started to get consistent numbers on every picture: 32 ms of input lag.
This is the hardware I used for the test:
Graphic interface: ATI Radeon 9700 Pro
Display 1: on VGA-port, LCD Monitor, Acer AL 1751 (low lag in theory)
Display 2: on HDMI-port, LCD HDTV, LG SL85
Resolution tested: 1280 x 1024
I know it's an LCD (although a fast one in theory) and I didn't test 1080 native resolution, but I just wanted to get some fast numbers as I was curious about it. I will try to get hold of a CRT to run the tests properly and hopefully get more accurate readings and pictures to publish here. I would also like to get a copy of the SMTT software(WinXP) if it's possible. And of course, any help with the tests and readings in general would be appreciated!
Cheers
-swexican
It's one of those things that drives you crazy once someone points it out to you. Don't make a big deal out of it, unless you can speed things up for them, in which case you can be the hero.
This is normal for LGs. They try to "help" you by changing or disabling some options. At least on my lowly 37LH20, none of them affect lag at all. Using the "Cinema" picture mode and any input label other than "PC" allows me to change the most options. "Expert" picture mode has even more, but it gets crazy complicated if you're not doing detailed calibration.
Wow, I don't think I've ever seen this timer give consistent numbers. Do try to snag a copy of SMTT from frito, it'll help a lot of confirm your numbers.
Finally, here are some real numbers for my LG 37LH20. I think I went overboard on the testing, but hopefully it will be a useful example of how it can be done and what things to consider.
Short Version:
The 37LH20's lag is 1.5 frames (25ms.)
Longer Version:
Total display lag, from incoming video to fully fired pixel, is 30ms. This is the sum of 21ms input lag and 9ms pixel response time. The "practical" total lag is somewhat less, about 25ms (1.5 frames), since pixel changes are visible before they have fully settled.
Upscaling of 480i content adds one additional frame of delay, for a total of 2.5 frames.
Tests Performed:
Interfaces and Resolutions:
HDMI - 1080p, 768p, 720p
VGA - 1360x768, 1280x720, 1024x768, 640x480
Component - 720p, 480i
Composite - 480i
TV Settings:
Input Labels (blank, PC, Game, etc.)
Picture modes (Cinema, Game)
Overscan on/off
Edge Enhancement on/off
Test Setup:
TV:
LG 37LH20-UA
LGD S-IPS panel (printed on sticker visible through center rear vent)
Manufacture Date: October 2009
Firmware Revision: unknown
Source PC:
Core 2 Duo 3 GHz
nVidia GeForce 8600GT with dual DVI outputs and component/composite TV output
Windows 7 64-bit
Latest DirectX, Windows Updates, and nVidia drivers as of 3/1/2010
SMTT application, 64-bit version
Reference Monitors:
Hitachi CM753 19" SVGA CRT
Commodore 1084 12" NTSC CRT
Camera:
Nikon Coolpix 4100
"Sports" Mode
(EXIF data claims 1/90th sec shutter, ISO 200)
Test Results:
Results were remarkably consistent across input types, HD resolutions, and TV settings. Most measurements only varied +-1ms, with just a few outliers that were not far beyond this. As a result, I'll only post a representative sample here. If anyone really wants to see dozens of very similar pics, or a table of values, I can certainly post them somewhere.
In this pic, the highest number on the CRT is 05.640. The highest number on the TV is 05.619. It is just starting to appear on the second row. This shows an input lag of 21ms. The highest number on the TV that is fully visible is 05.610, which indicates that took an additional 9ms for the pixels to fully respond. I don't know for sure if the camera exposure settings affect this reading, so it could be lower.
Standard-def (480i) results were similarly consistent, at 48ms (2.9 frames.)
The CRT is currently at 19.364 on row 2, and the TV is at about 19.322 on row 5 (42ms input lag.) The latest fully visible time is 19.317 (5ms pixel lag.) There are fewer rows at 480i, so the individual lag and pixel times aren't quite as accurate as for the HD tests, but the combined times are consistently around 48ms.
Other Tests:
I consider the SMTT results to be definitive, but I wanted to compare the accuracy to other common tests.
Using the flatpanels.dk timer, I tested three modes with 10 shots each. Individual values varied a lot (9-40ms), but the average was the same for each mode: 23ms, or 1.4 frames. This is fairly close to my "practical" figure of 1.5. Maybe this quick timer test isn't so bad after all.
I also tried a timer I found in this post http://www.avsforum.com/avs-vb/showt...4#post16445094 It averaged about 1.5 frames as well. I think this timer might be better than flatpanels.dk, but I haven't worked with it enough to know for sure. It's a little harder to interpret, but the values seem more consistent.
Not Tested:
There are a few picture settings I did not test: Noise Reduction, Dynamic Contrast, Dynamic Color, and "OPC." They didn't seem relevant for game/PC use. I suspect they would not cause additional lag, anyway.
I did not test the HDMI1 input. HDMI2 was used for all tests.
I couldn't get my video card to do 1080p or 768p on the component output in combination with the CRT. It's possible that the TV doesn't support them, anyway.
Additional Notes:
Picture modes can affect available options in the advanced picture menu. For example, Game forces edge enhancement to high. Cinema and Expert appear to have the most available options.
The only input label that has an effect is "PC". It disables most of the picture settings, and disables overscan for 720p sources. It does not affect input lag or general picture quality.
Even downscaling 1080p to 768p does not cause additional lag. It looks surprisingly good, too. I wouldn't want to use it with a PC full-time, but it would probably be better for Blu-Ray than using 720p upscaled to 768p.
PC display looks pretty nice at 1360x768. It may not be an ideal primary monitor, but it is fine for general HTPC use.
The VGA port does not work well. It didn't properly detect a 1360x768 signal. It reported it as 1024x768, and the image was shifted with a blank border on the right side. It wouldn't display 1280x720, but it did show 1024x768 and 640x480. (I did not test 800x600.) Image quality was fairly poor, except at 640x480. Since the VGA port doesn't affect lag, I see no good reason for using it.
Well, folks, that's it. My earlier suspicions were that the LH20 is a little slower than the Panasonic X1/S1 LCDs, but faster than most others. These tests confirm it.
I’ve had Rock Band set for 25ms lag for a while, and it feels just about right, so I'll be leaving it there. This is mostly what I cared about, but 3D games sometimes give me motion sickness if the controls aren't responsive enough, so it's certainly reassuring to know the lag is pretty low.
If you made it this far, thanks for reading!
Discussion starter · #514 ·
nice results guys, sorry i have yet to update the original post. i think i got 5 or 6 TV's to add to the list
hopefully we keep getting more test results so things stay up to date
i'll update the main post tonight to reflect the new tests
Discussion starter · #515 ·
Originally Posted by Viche /forum/post/18314411
We need to consolidate and clarify this info. It's getting to spread out and confusing.
So certain screen sizes of the A series has a decent lag time over its VGA connection, but image quality suffered.
Now on one particular 1080P C model was are seeing 30 ms when compared to an lcd monitor (I thought this means more like 47ms) in special mode (what the heck is that and was it not using a VGA connection?) and VGA mode (with a VGA adaptor fromt he game system I'm assuming) when LED motion setting turned on (what the heck is this and does it improve motion blurring)? We predict that turning on game mode will actually increase lag. And we have no confirmation of what the B series could or couldn't do.
I agree, when i update the first post tonight i will try to do this thanks for the advice
Thanks for a great report wondras! Just in time for my own report, this will help me a lot since my TV is also LG
On LG SL85 I know for sure picture quality worsens playing Xbox with input label set to "PC", and I really hope it affects input lag in a positive way. Both avforums.com and dday.it states 30ms on standard mode and 20ms and 10ms respectively in game/pc mode, but I fear their testings might have not been that accurate after all... Anyways, only my own tests will tell
-swexican
Do PC's suffer from the same input lag as consoles?
Consoles with all their scaling.
And in the end everyone saying Plasma is better for gaming?
I guess we have to wait till may for all the dankest TV's to get released...
I've waited 5 years to retire my 720p Panasonic Th-50PH9.
Maybe it's the TV or maybe it's my outdated 8800 GT but BC2 is choppy here and there(not server latency)
I'm waiting for Fermi to be released and bench-marked before deciding on getting a new card.(leaning Diamond 5850)
Discussion starter · #518 ·
sure input lag from a display is just as important with PC's
i use my TV as a monitor for my PC and play games on it all the time, it why i had to find one with very little input lag
Panasonic TV's in general tend to be some of the most consistent with low input lag regardless of picture settings or resolutions be it plasma or LCD.
LG LCD's and Sharp's in game mode would come the closest to them and perform good in the 30ms range most of the time.
Samsung Plasma's lag pretty bad though just like their LCD's for the most part from what i've seen so it really comes down to how much undefeatible image processing a certain display has in it and with many of the Current good PQ LCD's on the market the level of image processing needed and frame buffering that it takes to produce the images you see on screen result in some extremely laggy displays making them terrible for many types of games
Discussion starter · #520 ·
Originally Posted by NOOBZ1LLA /forum/post/18319476
In general which LCD manufacturer has less input lag, Sony or Samsung?
they are both the worst and which one is better will depend highly on the model specifically and what resolution your input is.
