Originally Posted by
lexluther25 /forum/post/15492708
Just as i thought this is what im hearing every were includeing the internet that the xbr4 is a better looking tv then the xbr6 and don't have as many features as the xbr4.
this is what cnet has to say about the xbr6
http://reviews.cnet.com/flat-panel-t...-33060608.html
The bad: Expensive; some color accuracy issues; black levels fluctuate somewhat in dark scenes; below-average screen uniformity; dejudder modes produce artifacts.
The bottom lineThe bottom line: The 52-inch Sony KDL-52XBR6 LCD is a bit too expensive for the level of picture quality
Despite delivering nearly perfect primary color accuracy in test patterns, in real life the display let us down
Unfortunately, like the Z4100 or the KDL-46W4100 we tested earlier, the XBR6 didn't maintain a constant level of black regardless of the brightness of the program material. The fluctuation in backlight intensity wasn't as noticeable as with the W4100--indeed, we didn't notice it at all during The Happening--but in certain scenes in other films we did see the XBR6's backlit dim and then brighten noticeably afterward. Our favorite test for this issue occurs at the 12:34 mark in I Am Legend, where the camera pushes into the dark bathroom. On both of the Sony sets, the entire screen became dimmer and when brighter, whereas the other displays maintained a constant level of black.
Color accuracy: The Sony performed well in this area, but still not as good as the Samsung A650 or the higher-end displays in our comparison. According to our measurements, the Sony XBR6 delivered very accurate color for the most part, coming extremely close to the D65 standard for grayscale, hitting the HD standard primary and secondary color points almost perfectly and exhibiting accurate color decoding. That's great, and in many colorful areas, the XBR6 delivered the goods, including the blues of Jess' jeans and the red blood dripping down Mrs. Jones' nose. The Sony's deep blacks also helped with saturation, making colors look a bit richer and more vibrant than on the displays with lighter black levels. However, all wasn't perfect.
First off, like many LCDs we've tested, the Sony veered into blue in its darkest areas, tingeing them a bluish color that became especially noticeable in shadows. One example came during the exterior of the farmhouse in Chapter 15, which had a bluish-purplish look to the skies and shadows and a similar cast on the near-black rooftop. Compared with the Samsung A650, however, which tinged those areas greenish, we still preferred the look of the Sony, although the Samsung A950 LCD and the plasmas were better than any of the other LCD at color accuracy in black and near-black areas.
Second and more puzzling, despite the accuracy of our measurements, we noticed that in program material skin tones especially, along with browns and other midtone areas, appeared more yellowish on the Sony LCDs--the XBR6 and the Z4100--than on our reference Pioneer or any of the other displays in the room. During the opening scene with the two girls sitting on the bench in Central Park, for example, their pale skin appeared more yellowish and slightly less flush than on the comparison sets. The same effect was visible in skin tones in other areas of the film, as well as in similar colors such as the light brown walls of the Moores' apartment. We also noticed that green, as in the plants and fields at Mrs. Jones' house, for example, looked more yellow than our reference displays.
Uniformity: Our review sample was a bit below-average in this category. In very dark or black areas we noticed a brighter patch in the upper-left corner of the XBR6, which also showed up in the letterbox bars of 2.35:1 aspect ratio films such as I Am Legend, and in black screens such as the credits or fields of stars. As usual with LCDs, the edges of the screen also appeared slightly brighter than the middle, although the difference was nearly impossible to detect outside of test patterns. When seen from off-angle, the image on the Sony's screen washed out and discolored at about the same rate as the other LCDs aside from the Samsung A950, which was noticeably worse.
Standard-definition: With standard-definition sources, the Sony fell a bit below-average. While it resolved every line of the DVD format, details in the grass and stone bridge appeared softer than we'd like to see. It removed jagged edges from moving diagonal lines and a waving American flag somewhat, although there were still more jaggies than on the other sets in our comparison. Sony's noise reduction is still excellent, cleaning up the noisiest areas of low-quality material almost completely in its strongest NR mode, and offering a great selection of NR settings between to deal with higher-quality material. Finally, like the W4100 and the Z4100, the XBR6 did engage film mode to remove the moire from the bleachers behind the speeding car on the HQV test disc, but it fell out and then back into film mode quickly, thus failing our 2:3 pulldown test. The results for this test were the same in both Auto 1 and Auto 2 CineMotion settings.
To much bad for me and i read some were else that the xbr6 don't do true 1080i and 1080p in moving images only steal images. I think i read that at hdguru.
the 950 is what im getting as well the xbr6 seems like it is a step down from xbr4.
Aand to the guy above bestbuy in store has the 950 marked down to $2200 and so does amazon. other places are $2500. Plus you can't compete with the 0led in the 950 for the price when teh xbr8 is $4000 and yes the xbr8 does rank well and im also a sony fan but when it comes to quailty picture and price the 950 will be the tv i will be getting. My good old xbr4 is going to my son.
on cnet they say even in standerd def the 950 looks great no wavy colors or lines. Hdguru named the 950 as king of lcds and cnet compares it's colors and blacks to plasmas.
