Our church just bought the Infocus LP790. I need to know the best way to connect a DVD player (has component out) and a computer to the projector that will be installed approx. 75 ft away. Would it be best to use component for the video and then run a separate line (what kind?) for the computer? Or should we run a two lines to a "switching box" and then just have one line going to the projector? The more I try to research this the worse it gets. The Infocus LP790 specs are here: Link
Thanks alot for any help you can give!
