cmjohnson,
I would check to see if the ATI Radeon 9200 card is compatible with your older motherboard. Motherboards of PII-400 vintage were usually AGP 1 or 2 while the 9200 is designed for 4 or 8. Also, you might also have a voltage incompatibility between the 9200 and the older motherboard. You could also be experiencing BIOS incompatibilities. I suggest that you toss the PI-400 motherboard and purchase a newer motherboard. Motherboards are pretty cheap now and you could purchase an AMD Athalon or Sempron with more than enough horse power to do what you want to do without spending a lot of cash.
TCIII
TCIII
