As a followup, here is the info from antennaweb.
red - vhf...KAIT-DT 8.1 ABC JONESBORO AR 74° 38.7 9
Originally Posted by Tnedator As a followup, here is the info from antennaweb. red - vhf...KAIT-DT 8.1 ABC JONESBORO AR 74° 38.7 9 |
Originally Posted by Tnedator the tower sits about 1500' above the level of my antenna, with nothing, including the top level of houses and trees above say 550'- 600' between me and the tower.. |
taz291819 said:Two things. Your home owners association can't tell you to take down the antenna (it's against the law), no matter if it's in a contract or not.
QUOTE]
I know, that's why I said above that I know they can no longer stop me, but there are no other houses in the neighborhood with antennas, so I just want to be as subtle as possible.
Originally Posted by jtbell So you have a clear line of sight to the transmitter. It's 37 miles away and puts out 18 kW. I have a digital station on channel 8, 68 miles away, putting out 44 kW. Assuming the signal falls off with the inverse square of the distance, your signal should be about (18/44)*(68/37)^2 = 1.4 times times stronger than mine, which works out to about 1.5 dB. Your terrain conditions look more favorable than mine, so it's probably even stronger. I get very good reception on my channel 8, except for some nearby-generated impulse noise, with a large VHF/UHF combo antenna (Radio Shack VU-190XR) on the roof, and a Channel Master 7777 preamp. The Winegard high-VHF antenna mentioned earlier has a couple dB more gain at channel 9, so it should work well. Even the smaller Radio Shack combos should be OK, because they're only a dB or so lower than mine at channel 9. For a detailed comparison, see http://www.hdtvprimer.com/ANTENNAS/comparing.html and scroll down a way for the graph that compares some VHF antennas. You can safely use a smaller preamp than the 7777. I also got good reception on channel 8 with a smaller indoor distribution amp (10 dB net gain after splitting the signal, I think; with the 7777 I get about 16 dB net after splitting). |
I just want to be as subtle as possible. |
