Installing boots on cable
642 Views 3 Replies 4 Participants Last post by  video321
I've got some CB-05 boots and Canare RG-6 with different connector types (BNC, RCA) to make patch cables. Having trouble installing the boots over the cable - very tight, won't move down the cable far enough to all strip/crimp.
What's the best way to ease the installation of the boots over the cable?
Status
Not open for further replies.
1 - 4 of 4 Posts
Heat the boots first and they should slide on easier.
Try white hand cleaner from the auto parts store.
It worked for putting handlebar grips on bicycles years ago.
1 - 4 of 4 Posts
Status
