1 - 5 of 5 Posts
If power goes out for a short time (5 seconds or so) and comes back on, do Insteon switches return to their pre-failure settings or do they come back in the "off" state?
I will have an auto-start generator and it would be nice if the electrical load was automatically cut before the generator kicked in. Then I could turn the lights/devices I wanted to have during the power failure back on once the generator was running.
If no one knows could someone do an experiment for me with a plug-in module? Plug a lamp into one, turn it on, pull it out of the wall plug, stick it back in and see if the lamp comes back on.
Yes,
All the Insteon modules/switches will come back on to "last state" after a power outage of any duration.
Cheers,
Paul
Discussion Starter · #5 ·
Originally Posted by SBSmarthomes /forum/post/0
Yes,
Cheers,
Paul
AVS forums are great. One question, two good responses. Thanks so much, guys.
1 - 5 of 5 Posts
