1 - 2 of 2 Posts
I purchased the Insteon IRLinc 2411r and Insteon Lamplincs to dim a few floor lamps when the my home theatre system starts up using Harmony Smart Control. If anyone has been able to make this work, could you let me know what steps to add to the "activity" in Harmony app.
If the lamplinc is not the right item, could you suggest an alternate Insteon dimmer product that can be programmed on the Harmony Smart control iPhone App.
I am very new to this. So far I have been able to successfully program all my devices to turn on and off with a single touch on the Harmony. The lights are the last piece of the puzzle where I am stuck.
Discussion Starter · #2 ·
I found the solution in a separate thread. Basically I had to go to the Power settings of the dimmer in myharmony and select "my device has no power button on remote". Now the lamp does not turn off automatically when I power off an activity.
1 - 2 of 2 Posts
