It is pointless to try to use ASIO for MP3, since that is a lossy format and you have already degraded the sound quality.
If you have CD or are using a lossless format, then your two options are ASIO and kernel streaming. I think Foobar2000 can do both. I believe there needs to be an ASIO driver for the sound device.
For DVD-Audio, the Audigy2 line of cards is the only one that can play protected DVD-Audio discs at the highest resolution.
