Yes, it's a radial clearance issue. Hmm, I could see the glass microspheres and loctite working reasonably well. I would have to support the rest of the rotor in the right orientation, and maybe slowly turn the motor while it sets to ensure that it's centered.
The wire may be easier to source (not sure where to look for microspheres, but I have Amazon Prime, so that's a good place to start). I'm estimating I would need quite thin wire, as the first fix I tried was wrapping with some electrical tape. I couldn't get more than one layer on before it would start to bunch up.
Off to do some figuring. Thanks for the ideas, I hadn't considered either!
