301 - 318 of 318 Posts
I just stumbled on Chris Hudlin's YouTube videos concerning his DIY rotary subwoofer builds. He's building a few of these for customers now and he seems to be tweaking the design as he builds new units. If you build this, some parts might go out of production and you would need to find suitable alternatives. Not a deal breaker.
Interesting. I wonder if he has ran into patent issues now that he is making for other people. I'm going to have to catch up with his builds!
I thought about that too. As long as he doesn't build a factory, he's not a threat. These aren't that easy to build and implement. Looking at the TRW-17 blades, I imagine there was a lot of aerodynamic research done on that design that's lacking in the DIY versions. The baffle would take care of the mechanical noise on the DIY build. Getting everything perfectly balanced and linear isn't critical either as we can't even hear the 2nd and 3rd harmonics of the rotary unit and the rotational speed will limit higher order harmonics. You need a full 360 degree rotation to produce a complete sinusoidal pressure wave. I doubt we can feel infrasonic harmonic distortion. This isn't rocket science, but you'd better be a good mechanic and fabricator.
Seems to me that what's required is a back and forth change in blade position, and that the motor rotation is irrelevant.
Pretty sure it's all covered in Chris Hudlin's YouTube videos.
I read and watched most of the build and the diy unit still requires periodic maintenance unless you have access to a metal lathe and milling machine to make it more robust! I'm still going to make one in the end regardless for my own interest. Chris seems to be a genuine nice bloke with no bull or excuses....
If I understood the explanation on the site, the rotation is constant, but the blade pitch determines the amplitude and polarity of the pressure wave. Pistonic diaphragms loose coupling as the frequency gets lower below resonance. The rotary subwoofer never does. As the frequency goes lower, there are more rotations per cycle and thus more displacement all the way down to DC.
https://www.soundandvision.com/content/eminent-technology-trw-17-rotary-subwoofer
http://www.rotarywoofer.com/
Soooo, in theory would you be able to achieve greater "output" by having a variable speed motor to change (increase) the RPM of the fan itself?
Seems like a higher fan speed would put more resistance on the subwoofer voice coil and almost act as a more stiff spider, increasing the fs of the driver making it more difficult to reach those lower frequencies. Sound logical?
Very very interesting topic.
I feel like the new Tymphany Peerless 15" would be an EXCELLENT candidate for this application given it's huge voice coil, ultra high power handling and (borderline asinine) claimed cone travel. I wonder if 2" of pitch in both directions would be too much?
Higher rotation speed will increase the efficiency and allow higher frequencies, but then it puts more strain on the system and increases the mechanical noises. It shouldn't reduce the low frequency limit, but would increase the output. I don't know what xmax is needed for full travel, but the driver should have good motor strength and have a vent hole in the magnet large enough for the rotational motor shaft to pass through. Once the cone and surround are removed, the spider is the only suspension left and will allow more travel.
DIY Rotary Subwoofer guide by Chris Hudlin
https://drive.google.com/file/d/0BwCZI3OjUVs1ZjktRnFZSG1HVzA/view
Premium Member
i've followed this thread from inception, specifically for the DIY aspect.
Despite having read ALL the Tom Swift books, from the turn of the previous century, and the "gee-whiz" factor it can light up in a 10 y.o.
the availability of "better" DIY components seems to be stalled in R&D.
but knowing were the weak links are is also progress . .mol
If there were a good bullet proof plan . . why not?
Interesting build for sure. My friend who does car audio shows builds subs, he built mine for my home theater and designed the box. He sent me a pic of this new sub he is working on. Dual motor 15 inch sub pushing 1500 watts rms. He says:
Alot of people think motor Force is constant. But it's strongest when the coil is centered in the Gap. Further the coil goes, the lower the motor Force.
Also the assumption is centering the coil in the Gap is optimum. It actually isn't. May have 60% one way, 40% opposite.
So using a computer program I find the gap center where it's 50%\50%.
I do this with both coils. The other trick is because of this the motor Force increases with movement, inductance stays lower, and Zmax doesn't go up as high as a standard design.
In a standard design, the more the coil moves, the higher the resistance. But because one coil is leaving the other coil is entering.
I'm hoping to have my proof of concept finished soon. Just finalizing the blade design and then need to test a new VFD. The first one I got was a dud.
  • Like
Reactions: brettus
Premium Member
not about the rotary but while this ^ is going "'around"
fire it up and get some measurements. .
TY
Good to hear. I did plan on making one of Chris Hudlin's designs at some point but due to life I'll probably have to settle for the BOSS designs instead along with my other bass shakers. Due to my room size there is no room gain below 20hz which required me to boost the guts out of my DIY PR subs previously. It was still good but that natural feeling of the room flexing compared to bass shakers is hard to emulate!
OMG some of those videos drag @$$.
But this concept is seriously intriguing.
I would like to see a final working setup and what room volume(s) thrive under these conditions.
I'll bet if perfected, it nets an entire new blow your hair back experience. ( Perfect for the iFly training room, lol)
Subscribed!
Sent from my Pixel 3a using Tapatalk
I can't stop thinking about the mechanics involved and what they sound like in person.
Basically...
It is very hard for me to even visualize proven speakers and how 35+ foot sound waves move around a room. Then you tell me how fast sound moves, it boggles my mind. Nothing helps me, not even tricks like the Schlieren Flow technique.
Anyone that has stood under a helicopter in idle knows that it is possible to rock your world using a simple spinning propeller but they are huge... And powerful.
I mean most of us can't even hear below 20hz. But like an elephant, we can still sense them in our own way. Using a Boss platform or bass shakers for tactile perception is freaking next level if you ask me, but since we are more connected than ever in the history time , I have to wonder if what the third level is!?
So stop reading stuff you knew in 3rd grade and get your savant butts back to work to unlock the ever growing mysteries of our amazing universe.
Hello-
Please forgive my resurrecting this since it's been almost 2 years since the last post, but I've been looking for Chris Hudlin's guide, and the links in these posts are no longer working. Does anybody have one that works, or is willing to share their file on Google or Dropbox? Filedropper seems to want money to use their "service". Thanks!
hey guys, the guide is complete!
the link: Free File Hosting - Online Storage; Upload Mp3, Videos, Music. Backup Files
the file is 65mb, rather large for a word document, but that cause of all the pics. its 20 pages long but wont take long to read. enjoy
