First, I am in no way a newbie... I sold HDTV's for about 3 years... but that was about a year ago. So don't worry that this is just some stupid little problem that a newb would have...
I have a Hitachi 57S500 and an older Toshiba DVD player... not prog scan but has component outs.
The rushmore DVD is 2.35:1... but when I pop it in... It is MUCH wider than 2.35:1... Probably 3.?+/1. And is clearly stretched out... everybody is clearly too wide.
If I then set it to 4:3 Expanded... It gives the picture more height... so it is more viewable, but It still seems wider than 2.35:1.
ANOTHER BIG PROBLEM I'M NOTICING....
When I pause a movie and change the aspect ratio on my TV... I notice that I am loosing some picture. When I have it set on 4:3... I see the full picture (small of course becuase of side and top bars)... but when I then set it to 16:9 standard... I loose a bit off the edges... maybe only 3/4 or 1'' of picture... but I definately loose some picture.
In comparison... it seems like the 4:3 Expanded picture (where it cuts a little off the edges and top to zoom in) has the EXACT same ammount of picture (as far as what is cut off the edges) as the 16:9 Standard... but the 16:9 standard of course is a wider picture.
I just don't get it... You shouldn't loose any picture with the 16:9 standard; should you? Add this mess with the rushmore debocle and I'm starting to think something is wrong with my tv.
Any thoughts?
Any thoughts?
