Found it difficult to think of an adequate title to my question!
We have a home theatre (HT) with a LG PVR HD Set-top Box (STB) which works fine when used in the HT. In the rest of the house we have a distributed analogue TV system with a normal terrestrial antenna system (via co-ax).
I would like to be able to take the coaxial output from the STB (which my LG PVR has) and transmit that to the rest of the house so I could watch a previously recorded program from the PVR HD on another TV in the house. I was thinking I could just use some kind of splitter to transmit the output back into the TV coax network, and tune the TV's around the rest of the house to receive that signal (probably some UHF frequency), just as I would if the PVR was plugged directly into the back of the TV. I believe that the LG PVR co-ax output is downscaled to SD as it works when plugged directly into the TV.
I hope I have described this OK and would appreciate any replies/suggestions.
