1 - 1 of 1 Posts
Interview - Wireless Outdoor TV
Joe Pantel of Surfside Concepts and Pantel Corp.
Currently, Pantel TVs operate wirelessly over an 802.11a WIFI signal that is able to transmit both audio and video data up to 200-ft away. This technology eliminates the problems that would be incurred if it were necessary to have a hardwire connection between the cable boxes/DVD players and the television. That would simply defeat the purpose of having an outdoor TV because cable boxes and DVD players are not made to withstand the elements of the outdoors.
The Pantel Outdoor Weatherproof TVs are made with powder-coated aluminum, which allows them to easily ventilate so that they don't overheat and it prevents them from rusting as a result of bombardment by rain or any other moisture. The bottom line is that the elements that exist in an outdoor setting will cause our TVs no harm. The internal electronic components of our TVs are completely sealed off so that they are not brought into contact with the elements that could so easily damage an indoor television.
Read the complete article at HomeToys.com
1 - 1 of 1 Posts
