Status
Not open for further replies.
1 - 2 of 2 Posts
My brother just got a Sony PFMB242 Plasma TV from his work (they were getting rid of them.... lucky ******* :p )
Anyway, he hooked it up thru S-Video for the time being, and on 2 separate occasions, the picture's colors inverted and stayed that way until we unplugged the TV. Basically people turned blue, blacks turned white, etc.
I checked the connections and all, and everything seems to be in order - has anyone had this problem?
Super Moderator
suggest you try another input- composite or component and see if the same problem is noted
Mark
1 - 2 of 2 Posts
Status
