Status
Not open for further replies.
1 - 3 of 3 Posts
has anyone been able to use a patch cable to connect from the IR Blaster jack to the IR remote receiver jack on the DHG-M55CV? I have a Showstopper HS1000 and can't seem to get it to play nice with my digital cable box. I'm not sure if the IR Blaster cable is working as I never used it before. I noticed on the back of the digital cable box there is a input jack for a remote IR receiver.
Thanks in advance
Are you sure it's an IR receiver jack on the cable box and not an IR blaster jack so the cable box can control a VCR?
And if it is a receiver jack, it probably needs something akin to an IR blaster (in reverse) sensor to operate. I doubt very much that it will allow for direct bridging between blaster ports.
Discussion Starter · #3 ·
Yes, I am sure of the type of input jack. I was hoping that someone who has this model box would have been able to shed some light. I have been able to get the irblaster to work with a different cable box.
Thanks for looking.
1 - 3 of 3 Posts
Status
