Hi,
I can't find any reference to this problem so I hope someone can help.
I have installed a three zone system consisting of two itach ir and one itach serial gateways and have programmed an iPad interface using iRule Builder 2. It works perfectly and connects to the gateways instantly except when another iPad is also in use i.e. someone is using an ipad to control the kitchen zone while another person is using an iPad to access cinema zone. When this happens it takes about 60 seconds to connect to gateway.
Router is Buffalo WZR-HP-G300NH. ip addresses on itachs are all fixed, no dhcp.
iPads are vers 1 and 2.
Has anyone come across this problem? I have the gateways connected to a gigabit switch plugged into a router.
Any help gratefully received.
