1 - 6 of 6 Posts
So I am about to buy a 7.1 receiver. I had planned on running 5.1 in the living room and having the second zone be the dining room. I thought of the idea of having zone 2 connect to a speaker selector so I could then run speakers to the patio and kitchen. So in my mind I could pick what zone go the power from zone 2. Not all at once.
When I research speaker selectors it seems like they all split the signal. Doesn't this drop the impedance of the receiver down and lower the volume over all?
While I would love to have sound in the living, dining, kitchen and patio at once I don't want to damage the receiver.
Is this what I am looking for in a product?
This is the receiver I plan to buy.
http://www.pioneerelectronics.com/PU...ers/VSX-1121-K
Banned
Impedance matching means exactly that...
Two pairs of 8 ohm speakers through a NON impedance matching makes 4 ohms(exactly what you said you are worried about)...
Two pairs of 8 ohm speakers through an impedance matching keeps the ohm load at 8(which is exactly why it is called IMPEDANCE MATCHING)...
About 10 yrs. ago I installed a Niles 6 speaker selector in my cousins house. It does 3 rooms, front porch, back porch and swimming pool. Originally we used an old Kenwood KR-7600 a yr ago he repalced it w/a Marantz AVR. The system has run w/out a hitch for the entire 10 yrs. Check out the Niles line, it's very reliable and easy to set up. BTW he's still using the Kenwood w/his Burhoes speakers. That was his setup in college back in 1978.
To answer your question, yes that or other similar products should work just fine, just be sure to activate protection circuit when more than 1 set of speakers are in use (in zone 2)
1 - 6 of 6 Posts
