Chris,
Does the user's manual say the DB15 connector accepts YPrPb? Unfortunately, Sharp doesn't seem to be bothering to put manuals on the Web.
As best I can tell from online information, the DB15 connector on the Sharp projector is only for computer RGBHV signals, not component YPrPb. Sharp's Web page says "Computer RGB exclusive x1 (D-sub 15 pin)." However, it might just be market-speak for saying it's their only HD projector with a DB15 connector.
See
http://www.sharp-usa.com/products/Mo...58,652,00.html
Most pre-made DB15 VGA-style cables use very thin wires. Their incrased resistance compared to standard 75 Ohm RG-6 cables causes significant signal attenuation if the cables have to be very long.
I'd suggest running both types of cables, especially if you're doing an in-wall or otherwise difficult cable installation. It's better to have too many cables than not enough: be sure to run cables for S-Video and composite signals, too.
It'd probably be best to use the shortest possible DB15-to-BNC breakout cables. They're readily available at most computer stores. Run 5 separate RG-6 cables for most of the distance.
Then you can select the appropriate video signal at the projector, instead of using an external switch. Some HDTV receivers do have RGB outputs on DB15 connectors. And you might decide to go with an HTPC at some time in the future.
I hope this helps a little.
