Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
Originally Posted by daviddeng /forum/post/16826292
Another question, I am framing the rack room, what is the depth of the equipment room your guys have? I have 29" does this good enough for air circulation?
Originally Posted by BIGmouthinDC /forum/post/16827713
The riser as shown is incorrect for this space. It should only go under the second row and it should extend wall to wall. I would move the doors away from the theater and create a space for the rack in an entrance hallway. Doors should open in not out. Then a rear access panel in the theater for doing the wiring.
Originally Posted by broconne /forum/post/16827761
BIG --
I was just wondering about this for my future theater.. Is there a reason a reason the doors should open in?
Originally Posted by BIGmouthinDC /forum/post/16827789
Same reason as bedrooms. In case of emergency nothing can block the door. You are on the side where you can move anything that has fallen in the way.
Originally Posted by Suntan /forum/post/16827921
Yeah, and then when you are unconscious inside, the doors can be blocked from the outside of the room so the firemen can't clear the obstruction to get into the room.![]()
Originally Posted by BIGmouthinDC /forum/post/16828062
But they come with the tools to get through the door. I doubt you take and ax or chain saw with you when you watch a movie.
Originally Posted by daviddeng /forum/post/16826905
there is a closet space between my home theater and bathroom, it is about 29" by 9 ft. very long and I am planing to put Rack into it, but not sure how to use rest of space, any suggestion?
