1 - 5 of 5 Posts
My receiver is out of my line of site and I'm having trouble controlling the volume of my receiver from my couch.
A friend mentioned that it is possible to set your tv to control the volume of the receiver via hdmi so I can just point my remote at the tv. It sounds fishy.. but is it possible?
I think it is called "HDMI Control" or something like that. You may need to turn the feature on in the setup menus of the receiver/TV.
Another option would be to add an IR repeater system. I set one of these up recently using the following items from Parts Express and it works perfectly:
http://www.parts-express.com/pe/show...number=182-315
http://www.parts-express.com/pe/show...number=182-314
http://www.parts-express.com/pe/show...number=182-305
http://www.parts-express.com/pe/show...number=182-317
-Max
Premium Member
Originally Posted by rzdh /forum/post/19560816
I have a Samsung UN55B6000 and an Onkyo HT-RC160.. How do I check to see if they support it?
The both do ... on Samsung devices it's called Anynet+ and on your Onkyo it's called HDMI Control (RIHD) (see p. 79 in your Owner's manual), although don't always work as desired depending on the individual components.
1 - 5 of 5 Posts
