My Wineuard works fine just sitting up in my attic. I have to just point it inthe general direction of the transmitters.
Originally posted by Sc0rp10n are there any special grounding requirements when mounting an antenna in the attic? or can you just mount the antenna and run your line to the preamp? |
Originally posted by Southern Soul Grounding was probably the primary reason I didn't mount outside. I have a CM 3019 in the attic with a channel Master distribution amplifier (no preamp). I get all signals available and live about 27 miles from the transmitters with about a 35 degree spread. You can always try it. |
Originally posted by sbender I use a Radio Shack outdoor UHF antenna and preamp in my attic. I live 20 miles from Baltimore and 30 miles from DC. I get flawless reception. I'd definitely recommend at least trying an attic install first. It obviously makes running cables much easier. |
