I have a Onkyo TX-SV828THX receiver from around 1997. There are a few quirky things going on with the receiver. This is only a 2.1 system. All equipment is plugged into 1 surge protector.
1. When I do a cold start with the reciever, there is a high amount of crackling coming from the front speakers, that isnt in the source material. The only way to stop this, is to crank the gain up all the way, and listen to the speakers for a few minutes, the crackling stops. I can even turn off the speakers switch (so that no sound comes from the speakers) and crank the gain up on the reciever all the way, wait for about 2 minutes, turn down the gain, turn the speaker switch on, and no crackling is to be heard. So this is one problem. Tried different speakers, same thing. All connections are using spade plugs and 16 guage cables.
2. Sometimes, for no apprent reason the subwoofer starts a low continuous rumble, ignoring the LFE information completely. If I turn off the reciever, and turn it on again, the rumbling goes away and starts acting normally.
3. Sometimes when I try the internal test tones of the reciever, it says "Error DSP" in the main panel, and the test tones crackle from both the speakers at the same time, while it shows that its only sending a signal to the left speaker. since its only a 2.1 system, I never use any DSPs anyway, I always leave it on bypass mode. I dont listen to the system at a super high volume either.
Any ideas about whats going on?
