Status
Not open for further replies.
1 - 5 of 5 Posts
Hi Folks,
I have a Sony Bravia XBR8 and noticed, that when using the vivid picture setting, the TV displays vertical white lines. It happens no matter what input I use (e.g. HDMI) and what device I use (e.g. Apple TV, Tivo, Cable, etc). This also happens whether I use my Sony Soundbar as the pass through or I connect devices directly to the TV.
Does this mean my TV is dying? What can be done?
Thanks for your help.
Evan
Best to buy a new set.
Thanks, where can I look for suggestions regarding what to purchase? It is so long since I bought a new TV and a lot changed. Any suggestions are appreciated.
Find a used plasma. No need to spend $4k or more for a OLED that has problems and i hate LED - LCD so i would never buy one of them.
Plenty of cheap stuff out there if you are ok with that.
1 - 5 of 5 Posts
Status
