I've got 2 Sony TVs. Both 65" rear projections, a KP-65WS500 and a KP-65WV600. The 600 has a burnt out blue bulb and the 500 has a cracked screen, I'd like to be able to make one good TV out of the two.
Ideally (assuming it will work in the other TV) I would replace the burnt out bulb in the 600 with the working one in the 500, again, if it's even possible. If it is, is it a DIY project?
The second option is to replace the broken screen with the newer one. I am assuming I can, and that it will fit.
Does anyone know if I'm on the right track? Are the lamps transferable etc...?
Thanks in advance,
Dok
Thanks in advance,
Dok
