Status
Not open for further replies.
1 - 3 of 3 Posts
Is there a DVI-HDCP Upgarde Path module for Pioneer Elite PRO-1000HD 50" Elite PureVision Plasma Monitor?
Specifically is there an "announced" repalceable module as on other Pioneer projectors, in the Pioneer Elite PRO-1000HD to add DVI-HDCP and possibly?
Are these not costly?
Murray Kerdman
First off, you know that the PRO1000HD is the same as the 503CMX with the glossy frame and an included video card right? I only say that so that anything you subsequently read about a 503CMX upgrade path you can be rest assured that it will apply to your display also.
Key Digital and Aurora are both doing DVI-HDCP cards that will replace your removeable video card in your slot.
There are two very long threads about both here:
High end option from Key Digital
Affordable, less feature rich version from Aurora
The threads discuss the design and connections and, if that is too much to read, I know the KD website has info on their card and the Aurora webiste porbably has info on its product also. OK just found them both:
KD card
Aurora card
Discussion Starter · #3 ·
Divvy,
Murray Kerdman
1 - 3 of 3 Posts
Status
