I'm wondering, is there a thing as too big of a subwoofer? I realise that say depending on room size, volume played, a huge sub might not be required, might be overkill, but can you have a too big subwoofer for a room/speakers? Would a smaller sub be better in some cases, or its always the bigger the better?
I'd guess that in subs bigger is always better.. If its too loud, you could probably just reduce its volume to fit whatever speaker..
Also is there such a thing as bigger/smaller being more musical? Or it really has to do with the components used?
