Originally Posted by dagman /forum/post/0
Which technologies do I want for true 1080p, no burn-in, and flat panel?
The automatic answer to your question would be LCD, but the question you should ask is what is really most important to you?
- Will you be watching the TV in a somewhat dark room and don't want black to look gray? If you do, then that probably eliminates LCD.
- Is it really important to have a flat screen? If it is, you'll be paying a premium for that.
- Do you have a problem with screen reflections? If so, then you'll probably want to stay away from plasmas and other glare screens.
- Is picture quality and cost most important to you? Then you really might want to check out 1080i CRT rear projection. They can certainly look better than almost all of the newer technology.
Personally I own the Sony SXRD with 1080p/60 inputs, and I agree with everyone that says that a 1080i input looks the same as 1080p/60. If you really want true 1080p, that would be 1080p/24. Only Pioneer currently sells a TV that can really accept that signal, but if you're like most people it doesn't matter anyway because you're probably totally okay with judder like you've watched for years.
