1 - 2 of 2 Posts
I have a Samsung flat screen LCD (not sure of the model exactly) and for a long time now, it's had a dark shadow spot (and one lesser shadow) in the middle of the screen. I don't remember when they came about and I have no idea how.
Does anybody know what could cause these shadows or how to fix them? It's really annoying sometimes.
Thanks guys.
Greg
Banned
Looks like the panel is failing possibly a gap between glare filter and panel or one of the diffuser panels either in front or back of the LCD panel . You can try to rub on it with a towel see what happens but not likely that it is fixable
Maybe something hit the screen kid's ball or something or a vigorous cleaning or just a failure of panel to stay together . Panel would cost more than a new set .
1 - 2 of 2 Posts
