1 - 3 of 3 Posts
I have a PLV-Z5 that is about 2 years old. It probably has less than 200 hours on the lamp and the orange light started flashing today which then shuts the projector off. It will no longer turn on. Is there a way to reset this light? I can't imaging the lamp needs replacement after only a couple hundred hours. I can't find anything in the instructions.
1 - 3 of 3 Posts
