Now Available: Tech Talk Podcast with Scott Wilkinson, Episode 19 Click here for details.
http://www.peerlessmounts.com/dyn/Pr...al_accessoriesQuote:
Originally Posted by Clint S. /forum/post/15505296
Does anyone know if anyone makes a corner mounted wall mount flat panel mount? (That's a lot of "mounts"). Like the typical wall mount, except for a corner of a room?
Bring $$$$
Otherwise: Google "corner wall mount"
Look at the articulating mounts; remembering that you want a stud(s) to hang it on.
Originally Posted by undermined /forum/post/15511223
i'd bet these guys make 1
http://www.chiefmfg.com/
Originally Posted by Clint S. /forum/post/15515358
OMG. They're insane, you ain't kidding. You could take a welding course, learn how to weld, and buy some welding equipment for that price and still have $ left over to buy a small island.![]()
That's what I've been doing since I posted this. I came across some Peerless mounts but ran away with my tail between my legs. I did see http://www.da-lite.com/products/prod...cID=13&pID=265 which can be found for less than 60 bucks, but I found out from them it's not a TV mount, you have to buy a wall mount to mount to that corner mount. Which is ok if it will take a standard wall mount. They didn't say that in their email reply, so I had to ask. I had originally asked them about the weight it supports, and he said the same weight as their wall mounts (200 lbs.). If they will take a typical wall mount, that would work ok.
Originally Posted by jayhawk11 /forum/post/15517286
You know that you can find Peerless on Amazon for super cheap, right? Take a look there. And I would go through Peerless again and double check that's the right bracket. The last time I ordered one for a client it was only about $500, and that was at retail pricing.
